2023
Learn to use Inspire Cast with our interactive tutorials.
Discover new features and enhancements.
New to Inspire Cast? Learn the basics here.
Explore Altair's resources for training and support.
Run a simulation of a gravity casting adjusting different components to see the effects on the results.
Step through setup and defining the rotation for a gravity tilt pouring casting simulation.
Set up a high pressure die casting simulation and see how to troubleshoot it.
Learn how to simulate a stalk and set up a pressure curve for a low pressure die casting simulation.
See the difference in porosity of a solid model and the same model with a core.
See how the two halves of a reflectionally symmetric part solidify when a chiller is added to one side.
Compare the solidification in a riser with that of risers with isothermal and exothermal sleeves.
Observe how a cooler helps maintain a homogeneous temperature range throughout a mold, particularly in high pressure die casting.
Create 2D sketches, surfaces, and solids with construction history and variables.
Designate casting parts, gravity direction, gates, and components.
Run a casting analysis to minimize defects and prevent manufacturing problems.
Download the Casting Benchmark Manual to learn more about benchmark and verification tests.
