On-Demand Libraries
Optionally install on-demand libraries through the Extension Manager.
Note that when using the Extension Manager as a library loader, commands in use through the loader.oml and unload.oml files may affect the behavior of the Extension Manager.
Altair CAE Readers and Writers
This extension contains Altair CAE Reader and Writer libraries.
Modules
- ABF - Commands used to create and write data in Altair Binary format (*.ABF).
- CAE Readers - Commands use Altair Readers to read data from a given CAE results file.
- CAE Readers 3D - Commands use Altair Readers to read data that require access to model information like corner data, averaging method, layer, and coordinate systems.
- CAE Writers - Commands used to create, write (new and append) data in Altair H3D format.
- CAE Reader Utility - GUI Utility to manually select and get commands for extracting data from a CAE/Test result file.
Altair Production Integration
This extension contains Hyperstudy Python Fit and Multibody Postprocessing workflow.
Modules
- Multibody Processing - This library supports multibody-related and multi-disciplinary workflows and system-level vibration analysis in time and frequency domains.
- Hstpyfit - Commands read and evaluate Hyperstudy .pyfit.
Altair Advance Optimization
This extension contains advance optimization algorithms.
- arsm - Find the constrained minimum of a real function.
- arsmoptimset - Specify the arsm optimization function options.
- grsm - Find the constrained minima of a real multi-objective function.
- grsmoptimset - Specify the grsm optimization function options.
- moga - Find constrained minima of a real multi-objective function.
- mogaoptimset - Specify moga optimization function options.
Install a Library in the Extension Manager
Uninstall a Library in the Extension Manager
Using the librarymanager Function
When using the librarymanager function to install or uninstall a native, on-demand library, the library status (installed or uninstalled) that you define wih the function is automatically reflected in the Extension Manager.
