Assign mesh shadow to faces
Assign mesh shadow
To assign a Shadow Face to the faces:
Stage Action
1 Activate the command Assign shadow to faces (see next block)
→ An assignment box is opened.
2
Complete the assignment box:
  • select the faces on which the shading will be assigned
  • in the list proposed choose the shadow
  • click on OK
→ The shading has been assigned to the faces.
3
Continue the sequence of assignment:
  • return to stage 2
Quit the sequence of assignment:
  • click on Cancel
To activate the command Assign shadow to faces, which requires the selection of data, choose one of the methods in the following figure:
