Altair® Flux®  2023 Documentation
2023
  1. Home
  2. Flux
    Flux is a finite element software for low-frequency electromagnetic and thermal simulations. Both, 2D and 3D solutions are available...
  3. Physical applications
    Flux allows to model different physical phenomena, and includes various applications (magnetic, electrical, thermal and thermal coupled).
  4. Magnetic applications: principles
  5. Computation of iron losses
  • User guide
  • What's new?
  • "How to" Documents
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Identification
  • Altair Material Datacenter (AMDC)
  • Material Manager
  • Flux e-Machine Toolbox
  • Flux Examples
  • Flux in SimLab Examples
  • Mementos
  • Macros
  • PyFlux Documentation (Beta version)
  • Flux installation guide
  • Flux Starting Guide
2023
  • User guide
    The user guide gives information about principles and how to use Altair® Flux® 2023.
  • What's new?
    See the release notes of the last and previous versions, with the necessary information on new features.
    See a list of documents to understand how to use certain features.
  • Flux Supervisor
    The Flux supervisor allows to run projects, examples, pythons scripts; to configure user preferences; to access tools...
  • Flux
    • General operation
      Here is a presentation of the Flux environment; the project management, the data management, the command language, the formulas and mathematical functions.
    • Construction of a Flux project
      The construction of a Flux project consists of several stages: Geometry → Mesh → Physics → Resolution → Postprocessing; with the possibility to import a CAD file, a mesh, materials...
    • Physical applications
      • Physics: principles
      • Magnetic applications: principles
        • Magnetic applications: overview
        • Magneto Static application: principles
        • Magneto Static - Integral Method : principles
        • Transient Magnetic application: principles
        • Steady State AC Magnetic application: principles
        • Computation of iron losses
          • Computation of iron losses: about
          • Iron losses model
          • Iron losses computation on regions
          • Iron losses multiparametric computation
          • LS iron losses computation on point
          • LS model identification with MILS
        • Energy balance / power balance: principles
      • Magnetic applications: software aspects
      • Electric applications: principles
      • Electric applications: software aspects
      • Thermal applications: principles
      • Thermal applications: software aspects
      • Coupled applications: principles
    • Circuit and Kinematic Couplings
      Flux is coupled to a circuit context allowing to model the sources of the devices.Flux also allow to model the movement via a kinematic coupling.
    • Co-simulation between Flux and another software
      Flux is able to couple with several softwares allowing to model mutliphysics phenomena.
    • Dedicated couplings
      Several dedicated couplings are implemented in Flux to, carry out vibro-acoustic studies, magneto-thermal studies and more.
    • 3D Overlay
      Flux has predefined models for rotating machines via Overlays allowing to describe a geometry, a mesh and a physics adapted to the wished machine.
    • Flux API
    • How to Configure the Memory in Flux?
  • Flux Skew
    Flux Skew is a module dedicated to the analysis of rotating electric machines with skewing, allowing a straightforward geometric and physical description in 2D and the consideration of continuous or step skewing effects.
  • Flux PEEC
    Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also provides RLC extraction and generation of SPICE-like equivalent circuits.
    Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification of the coefficients required to create material in Flux.
    AMDC is a comprehensive material database maintained by Altair and partner suppliers of engineering materials. Ready-to-use, Flux-compatible models may be obtained directly from this database for a growing number of materials.
  • Material Manager
    Flux has a material manager with its own material base.The user can create his own material base and import them into the Flux models to be studied.
    FeMt is a application in Flux dedicated for Electric Machine which permits to compute and postprocess results like efficiency maps.
  • Flux Examples
    See the lists of examples 2D, 3D, SKEW and PEEC with all available documents and all project and python files.
    See the lists of 2D and 3D SimLab examples using the Flux solver, with all available documents, *.slb databases and all script files.
  • Mementos
    See a list of Memento documents to understand certain Flux features.
  • Macros
    Flux proposes several macros enabling doing actions that are not yet implemented in Flux.
    This documentation deals with the Jython script used in Flux and allows to understand the various structures of entities and functions, and use it in user scripts for example.
    This document provides instructions for Flux installation on supported platforms.
    Several short videos to start with Flux.
2023
  1. Home
  2. Flux
  • User guide
  • What's new?
  • Flux Supervisor
  • Flux
  • Flux Skew
  • Flux PEEC
  • Material Manager
  • Flux Examples
  • Mementos
  • Macros
Introduction
This chapter deals with the computation of magnetic losses.
Contents
  • Iron losses model
