Switch and semi-conductor components: overview
Introduction
The semi-conductor components are of four types:
- the switch
 - the diode
Utilization
The semi-conductor components switch, diode are available only in transient applications .
In fact, it deals with the commanded components, and their state (on, off) is time dependent.
Overview
In a general way the semi-conductor components are defined by:
- a current-voltage characteristic
 - a command mode
Two models are available for this characteristic:
- Ron-Roff model
 - Exponentiel model
These two models are described in the following paragraph (§ Semi-conductor components: diode model ).
The semi-conductors components are presented in the table below.
| Component | Model for the current-voltage characteristic | Command mode | |
| ignition | extinction | ||
| Switch | Ron-Roff | controlled | controlled |
| Diode | Ron-Roff / Exponential | natural | natural |
