Constructing the command files for the data exchange
Introduction
To exchange the files automatically between two applications of different nature it is necessary to build command files for the execution of each application by means of a language appropriate to the software used. In the case of a Flux application the PyFlux language is used.
To build the command files in the PyFlux language for a Flux application one must know how to:
- recuperate the PyFlux syntaxes ( cf How to find out the syntax of PyFlux expressions? )
- manage synchronization (cf Implementing an automatic synchronization )
 - test the precision of the data exchange (cf Testing the computation precision )
Where to find examples?
The user can rely on examples developed within the tutorials to create their own command files:
- 2D technical specification: Induction Heating with multiphysics
 - 3D technical specification: Conduction Heating with multiphysics
