Creation of a spatial quantity by importation
Introduction
The user can create a spatial quantity by importing one file containing the coordinates of the nodes and of the associated values of the quantity.
Conditions of use
It permits exchanges of data without the need of using the multiphysics session.
Imported file
A tabulated spatial quantity can be created via importation of a file containing specific data for each node. Differents formats are available:
| Format | Description |
| *.DEX |
                         DEX = Data EXchange format specific to Flux  |
| *.IP | IP is a format for the Fluent software |
| Tabulated | The user enters the coordinates of the points manually |
Importation option
If the nodes of the selected support are different from the points of the imported file, the user can chose an importation option between:
| Importation option | Description |
| Node to node | |
| By proximity |
                         Permits to take the node located at the nearest point of the file. The user has to specify the maximum distance allowed between the nodes and the points of the file.  |
Creating a spatial quantity by import
To create a tabulated spatial quantity by import:
| Step | Action |
| 1 |
                         In the menu Parameter/Quantity:
| → | A dialog box «New tabulated spatial quantity … » is opened |
| 2 | Choose the Name of the spatial quantity |
| 3 |
                         Choose the support for importation:
| 4 |
                         Specify the file to be imported:
| 5 |
                         Choose the import option between:
 or
| 6 | Choose the position of the mechanical set (if any) |
| 7 | Validate by OK |
