Deletion of a component of the circuit in the circuit editor context
Introduction
In the circuit editor context, the components of an electric circuit can be deleted starting from two places: the Data tree or the Graphic sheet
Delete a component in the Data tree
To delete a component starting from the Data tree:
Step Action
1
Select the component to be deleted:
  • point and click on the desired component in the Data tree
→ The component is highlighted
2
Delete the selected component:
  • click on the selected component and choose Delete command
or
  • use the Del keyboard key
→ The component has been destroyed
Delete one (more) component(s) in the graphic sheet
To delete one (some) components(s) in the Graphic sheet :
Step Action
1
Select the component(s) to delete ( selection )
  • Point and click on the desired component(s) in the graphic zone
→ The component(s) (which can be of different types) are shining
2
Delete the selected component(s):
  • click on the icon
or
or
  • click on Delete in the Circuit menu
→ The selection has been deleted
