Data export to AcuSolve
- Time heat volume density exports, generate a .nas file of heat density variation versus time to the elements, compatible with AcuSolve. Only real scalar data collections, transient, multi-steps and computed to the elements, are compatible with these exports. The user should specify:
- The time interval to be exported. An error message appears if there is no data for one or several steps of a chosen interval for the data collection to be exported
 - Exports of static heat density generate a .nas file of heat density to the elements at current step. Only real scalar data collections computed on the elements are compatible with these exports.
No matters their type, exports to AcuSolve must be defined by:
- File name
