Simplified projective method dedicated to rotating machines
Introduction
This chapter discusses the use of the Simplified projective method dedicated to rotating machines to create force collections in the Import / Export data context : this type of collection allows the computation of forces on a mesh and exporting the data to OptiStruct, to setup a NVH analysis of an electrical machine.
The following topics are covered in this page:
- Description of the approach;
 - Creation of this force collection;
 - Limitations;
 - Example of application.
Figure 1. Permanent magnet synchronous machine with two data supports: (a) the OptiStruct-imported support to collect the data and (b) the virtual cylinder.
Creation of this collection
- In the data tree, select the menu Forces data collection
 - In the dialog box New Forces data collection, select Simplified projective method dedicated to rotating machines
 - In the Collection support drop-down menu, select the data support on which data will be collected.
 - For the definition of the virtual support, two options are available in the
                            Definition of the computation cylinder drop-down menu. They
                            are:
- User defined: in this case, the cylinder radius,  its
                                    length unit and  the number of computation points
                                    along the perimeter must be provided manually.Note: The number of computation points along the perimeter field is pre-filled with 1080 computation points.Automatically defined: in this case, Flux will automatically determine the radius of the cylinder and its discretization.Note: The Automatically defined option is not available in Flux 3D.
 - Finally, choose the interval for data collection in the Collect
                            interval drop-down menu. The following options are available:
- Collect for all the steps of the scenario
 - Collect only for the current step
 - Collect for a specified interval: in this case, choose the parameter and its minimum and maximum values definining the selected interval of the scenario.
 - Click OK.
 - Right click on the forces data collection just created in the data tree and run the Collect data command.
Limitations
- The support to collect the data must be cylindrical and centered on (0,0) in the XY plane, even for 3D and Skew applications.
 - The axial forces (i.e. along the cylinder axis) are equal to 0.
 - The virtual support and the support to collect the data must be in the same mechanical set.
 - The radius chosen for the virtual data support must not be stuck in the rotor or in the stator parts and the virtual support must result in an air or vacuum region.
In this example, the goal is computing the global force on each tooth of the electrical machine shown in Figure 1 after solving a scenario in Flux.
To achieve this, a support to collect the data is imported from OptiStruct, as showin in part (a) of Figure 1. On this support, forces are computed with the Simplified projective method dedicated to rotating machines as described in the previous section.
The radius automatically computed by Flux is located between the sliding cylinder (which corresponds to the line between the different mechanical set entities) and the stator region, as shown in the figure below:
Figure 2. Definition of the radius for the virtual support: in red the sliding cylinder, in black the virtual cylinder to compute the magnetic pressures.
Figure 3. Visualization of global forces per tooth for a permanent magnet synchronous machine: (a) the forces normal to the collect support, (b) the forces tangential to the collect support.
