Formula with I/O (input/output) parameters
Definition
A formula with I/O parameters is an expression that allows handling I/O parameters in different contexts – physics, kinematics, circuit, results post-processing.
Use
A formula with I/O parameters is used to define:
- another I/O parameter
 - the current in a coil, a sensor, …
Evaluation
The formula is evaluated:
- during the solving process by using information on control of the parameter
 - during the evaluation of sensors in the context of results post-processing
The example below shows the use of a formula in the physical context for a magnetic application.
The value of the current in a coil is given by I = I0 sin(ωt)
The I/O parameter CURRENT_VAL can be expressed as function of other I/O parameters (I0, FREQ, TIME) by using the following formula:
CURRENT_VAL=I0*(2*PI*FREQ*TIME)
Additional information
Additional information on I/O parameters and corresponding formulas is available in chapter Parametric analysis: principles .
