Geometry importation: IGES / STEP standard format
IGES and STEP formats
The standard formats IGES / STEP enable the direct importation of geometry. These two formats enable the importation of complex faces (starting from version 9).
Warning: These formats are not available on the UNIX systems.
Conversion
The entities of initial file in IGES / STEP formats are read and converted into Flux entities as in table below.
| Entities of initial file | are converted into … |
| points | points defined by parameterized coordinates |
| lines |
                         lines of type:
| faces |
                         faces of type:
Options for conversion
The choice of the general options for conversion is not proposed to the user at the time of the importation. Flux imposes the default options (Coordinate system: IGES_i / STEP_i; length unit: the meter; precision: automatic).
