Update of the current value of a multiphysics I/O parameter
Introduction
During a multiphysics session, the user can update the current value of a multiphysics I/O parameter.
This value will be taken into consideration for the calculus of the next step.
The update is done by means of the command Update current value of a multiphysics I/O parameter.
Condition
To be able to update the current value of a multiphysics I/O parameter the current step must be put at zero or initialized.
Update of current value of an I/O parameter
To update the current value of a multiphysics I/O parameter:
Step Action
1
In the menu Parameter/Quantity:
  • point on I/O parameter
  • activate the command Update current value of a multiphysics I/O parameter
→ A dialog box «Update current value of a multiphysics I/O parameter» is opened
2 Choose the multiphysics I/O parameter to be updated
3 Introduce the current value of the parameter to be applied
4 Validate by OK
