Geometry building process
Outline
An outline of the geometry building process is presented in the table below. The different steps are detailed in the following blocks.
| Step | Description |
| 1 | Device analysis |
| 2 | Definition of the study domain |
| 3 | Preparation of the geometric construction tools |
| 4 | Ascending construction of the geometry |
| 5 | Regrouping in regions |
Device analysis (1)
The first step of the geometry building process is the device analysis :
- to define the study domain, and
 - to prepare the geometric description
The questions that could arise at this level, before starting the description itself, are grouped in the tables below (non exhaustive list).
| Analysis to: | Device features |
| define the study domain |
| prepare the geometric description |
| Analysis to: | Is it necessary |
| prepare the mesh |
| prepare the physical description |
Next steps (2, 3, 4, 5)
The other steps of the geometry building process are described in the table below.
                         Step of …  |
                     The user | ||
| creates… | builds… | assigns… | |
| Defining the study domain (2) |
                         the symmetries the periodicities the infinite box  |
| Preparing the geometric building tools (3) |
                         the geometric parameters the local coordinate systems the transformations  |
| Ascending construction of the geometry (4) |
                         the points the lines  |
                         the faces the volumes  |
| Regrouping in regions (5) |
                         the point regions the line regions the face regions the volume regions  |
                     the regions to points, lines, faces, volumes respectively | |
Operations order
The different steps were presented in a “chronological” building order.
In practice, the geometry building process is not always linear and the user proceeds by successive steps. In this case, he makes “go and return” between different steps.
