User sub routines (Groovy): How using paramSpatialCurrent[k,v]?
| Example | Create a new 2D magneto static project. This is a plan project, with a depth of domain of 50 mm. | |
| 1 |
                         2 Define:  |
                         Creates a spatial quantity, a 3D vector:
 x = 5000, y = 5, z = 0.  |
                         Create a linear magnet “ MAGNET ” described by the Br module:
                         Create an user material “ MAT_1 ”:
                         3 Attribute the material to the faces region Attribute the region to the face…  |
                         Create face region “ MAGNET ”, “ AIR ” and “ STEEL ” Assign the material “ MAT_1 ” to the “ STEEL ” region … Assign the material “ MAGNET ” to the “ MAGNET ” region … For the magnet region, give a magnetic direction (following axis x…) Assign faces region to faces… and so on….  |
| 4 |
                         Click on the “ Edit user function ” to see and modify into the python editor the groovy sub routine “MaterialLaw.groovy”. These files are in the directory: “....YOUR_FLUX_PROJECT.FLU\persistent\groovy ”  |
| 5 |
                         Type the following groovy (step 8) code in the sub routine public void compute (){} : User parameter is paramSpatialCurrent“Vector_mur”. This is a double value type. The first component starts with the 0 pointer. Note: In the key “Vector_mur” the first letter is
                              writing with an upper case and the following, in lower case.
| 6 | ![]()  |
| 7 | Solve the project | |
                         8 x= 5000, y = 5, z = 0.  |
| 9 |
                         Delete the previous results and modify the Vector_mur components: x = 5, y = 5000, z = 0 solve again the flux project:  |
| 10 |
