Delete results
Introduction
To each solving scenario are associated:
a set of finite element solutions (SOLVE_FLU_i.EFL files) in the project directory
 - a set of results (results associated to the sensors, …)
Management of results
If some steps are not correct or if there is an error in the scenario definition, it is then possible to delete the results associated to the computation steps.
Attention: the management of results and the management of the computation steps are independent.
If in a scenario the results are deleted, the definition of the computation steps is remained within the scenario.
Delete results
To delete results, follow the steps below:
| Step | Action |
| 1 |
                         In the Solving menu, point on Delete the results and choose one of the following options:
| 2 | Click on OK |
                         For each step:
