getNbcName()
Return the name of a node specified by its ID.
Usage
nbcName = vis.getNbcName( nbcId )
nbcId (integer)
Node ID.
Return Value
nbcName (string)
Node name corresponding to the node ID.
nbcId should be valid.
This routine returns the name of a node specified by its ID which is given by nbcId. For example,
nbcName = vis.getNbcName( 1 )
