getSolRatioSteps()
Return the "Solution Ratio" steps value.
Usage
solRatioSteps = adb.getSolRatioSteps( var, type = 'all' )
- var (string) or (integer)
- The "Solution Ratio" variable name/index.
- type (string)
- The type value; 'all', 'initial' and 'final'.
Return Value
- solRatioSteps (numarray)
- The "Solution Ratio" step values.
var must be a valid name or index.
type must be 'all', 'initial' or 'final'.
solRatioSteps = adb.getSolRatioSteps( 'pressure' )
