AcuProj
Project the solution fields of a solved problem to another mesh.
acuProj [options]
AcuSolve Preparatory Program
AcuProj is a simple utility program that projects the solution from the restart files of a solved problem with one mesh to another mesh. The generated files are suitable for inclusion in the NODAL_INITIAL_CONDITION command of the new problem.
In the following, the full name of each option is followed by its abbreviated name and its type. For a general description of option specifications, see Command Line Options and Configuration Files. See below for more individual option details:
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values, and the place where each option is set.
- problem or pb (string)
- The name of the problem is specified via this option. All generated file names start with this name.
- coordinates_file or crd (string)
- The coordinates file for the new mesh. The file must contain four columns: node number and x, y, z coordinates. If coordinates_file is set to _auto, problem.crd and problem.crd.B are assumed.
- from_problem or fpb (string)
- The name of the solved problem is specified via this option. If from_problem is set to _auto, the name of the problem option is used.
- from_working_directory or fdir (string)
- The working directory of the solved problem. If a relative directory address is provided, that is, the directory does not start with an "/", it is considered relative to the from_problem_directory.
- from_problem_directory or fpdir (string)
- The home directory of the solved problem.
- from_run_id or run (integer)
- The run number of the solved problem from which the projection is requested. If from_run_id is set to 0, the last eligible run is assumed; see description below for more details.
- from_time_step or ts (integer)
- The time step of the solved problem from which the projection is requested. If from_time_step is set to 0, the last available time step consistent with from_run_id is assumed; see description below for more details.
- search_technique or search (enumerated)
- Technique for evaluating the projection:
- node
- Choose the value of the closest node.
- element
- Perform element interpolation.
- line_buff or lbuff (boolean)
- Flush standard output after each line of output.
- verbose or v (integer)
- Set the verbose level for printing information to the screen. Each higher verbose level prints more information. If verbose is set to 0, or less, only warning and error messages are printed. If verbose is set to 1, basic processing information is printed in addition to warning and error messages. This level is recommended. verbose levels greater than 1 provide information useful only for debugging.
Examples
acuProj -pb channel -crd channel.crd -fpb channel -fpdir ../channel1problem = channel
coordinates_file = channel.crd
from_problem = channel
from_problem_directory = ../channel1acuProjNODAL_INITIAL_CONDITION ( velocity ) {
nodal_values = Read( "channel.vel.nic" )
NODAL_INITIAL_CONDITION ( pressure ) {
nodal_values = Read( "channel.pres.nic" )
}- Nodal Field
- File Name
- velocity
- problem.vel.nic
- pressure
- problem.pres.nic
- temperature
- problem.temp.nic
- species
- problem.spec_id.nic
- eddy viscosity
- problem.eddy.nic
- turbulence kinetic energy
- problem.tke.nic
- turbulence eddy frequency
- problem.tomega.nic
- viscoelastic stress
- problem.vest.nic
For the species field, ID ranges from 1 to the number of species.
The options from_run_id and from_time_step specify the restart run and time step to extract the data. Either or both options may be set to 0, indicating the use of the latest data:
| from_run_id | from_time_step | Approach |
| >0 | >0 | Use the restart data from the specified run and time step |
| 0 | >0 | Use the restart data from highest run that has the specified restart time step |
| >0 | 0 | Use the restart data from the last time step of the specified run |
| 0 | 0 | Use the restart data from the latest run and time step |
The physical domains of the two meshes do not need to match. If a nodal point of the new mesh falls outside the domain of the solved mesh, the values on the boundary node of the solved mesh closest to the node under consideration are used.
Two projection methods are available: node and element. The node search technique assigns the values of the closest node from the solved problem, whereas the element search technique performs an element interpolation. The latter technique is more accurate, but potentially much more expensive.
