udfGetEbcMedium()
Return the medium of the boundary element set.
name = udfGetEbcMedium( udfHd ) ;
AcuSolve User-Defined Example Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- name (integer)
- Symbolic name corresponding to the medium of the boundary element set.
- PRM_MED_FLUID
- Fluid.
- PRM_MED_SOLID
- Solid.
- PRM_MED_SHELL
- Shell.
Integer medium ;
medium = udfGetEbcMedium( udfHd ) ;
if ( medium == PRM_MED_FLUID ) {
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within an Element Boundary Condition user function.
