udfGetFanData()
Return data of a fan component.
fanData = udfGetFanData( udfHd, setName, dataName ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- setName (string)
- Name of the FAN_COMPONENT set.
- dataName (integer)
- Symbolic name of the requested data.
- UDF_FAN_AREA
- Inlet area.
- UDF_FAN_MASS_FLUX
- Inlet mass flux.
- UDF_FAN_AVERAGE_VELOCITY
- Mass-averaged inlet velocity.
Return Value
- fanData(real)
- Pointer to one-dimensional real array of the requested data. The dimension of the array is one for all values of dataName.
Real* fanData ;
Real area, mass, velocity;
fanData = udfGetFanData( udfHd, "fan", UDF_FAN_AREA ) ;
area = fanData[0] ;
fanData = udfGetFanData( udfHd, "fan", UDF_FAN_MASS_FLUX ) ;
mass = fanData[0] ;
fanData = udfGetFanData( udfHd, "fan", UDF_FAN_AVERAGE_VELOCITY ) ;
velocity = fanData[0] ;Errors
- This routine expects a valid udfHd.
- setName must be a valid name.
- dataName must be one of the values given above.
