udfGetNumSdNodes()
Return the number of nodes in the subdomain.
nNodes = udfGetNumSdNodes( udfHd ) ;
AcuSolve User-Defined Subdomain Routine
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nNodes (integer)
- Number of nodes in the subdomain.
Integer* nNodes ;
nNodes = udfGetNumSdNodes( udfHd ) ;Errors
- This routine expects a valid udfHd.
- This routine may only be called within an external code.
