ACU-T: 2400 Supersonic Flow in a Converging-Diverging Nozzle
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction
Problem Description
The exit to throat area ratio of the nozzle is 1.5. The radius at the inlet is 0.892 m, while the radius at the outlet is 0.691 m. The inlet stagnation pressure and the inlet temperature are 123,567 Pa and 309.072 K, respectively. The static pressure at the outlet is set to 101,325 Pa. The fluid in this problem is air, where the flow is assumed inviscid (viscosity and conductivity are zero) and density is based on the ideal gas model.
The AcuSolve simulation will be set up to model a transient supersonic flow where the flow variables reach an asymptotic state to determine the stable flow solution.
Validate the Geometry
Set Up Flow
Define Material Properties
Verify the Material Selection
Generate the Mesh
Run AcuSolve
Post-Process the Results with HM-CFD Post
In this step, you will check the contours of pressure on a mid slice plane.
