ACU-T:3401 / SL-2411 Electric Motor Analysis using AcuSolve-Flux One-Way Coupling
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction. To run this simulation, you will need access to a licensed version of SimLab and AcuSolve. You will need an internet connection to watch the video tutorials and download the files.
This tutorial works directly from the solution setup. Before you begin download the SimLab database
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
