ACU-T: 4101 T-Junction Flow using the Eulerian Multiphase Model
Prerequisites
This tutorial provides the instructions for setting up and running a basic transient multiphase simulation using the Eulerian multiphase model. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
Validate the Geometry
Set Up Flow
Assign Material Properties
Generate the Mesh
Define Nodal Outputs
Run AcuSolve
Post-Process the Results with HM-CFD Post
Summary
In this tutorial, you learned how to set up and solve a multiphase flow simulation using the Eulerian multiphase model available in AcuSolve using HyperMesh CFD. You started by importing the HyperMesh CFD input database and then defined the flow setup. Once the solution was computed, you created a contour plot of velocity and field volume fraction using HyperMesh CFD Post.
