ACU-T:4300 / SL 2240 Species Transport Modeling
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 UI Introduction. To run this simulation, you will need access to a licensed version of SimLab and AcuSolve. You will need an internet connection to watch the video tutorials and download the files.
You can work through this tutorial in 2 different ways:
  1. Complete tutorial - CAD to Results
    This provides a complete workflow starting from creating CAD, generating mesh, and setting up the simulation to visualizing the results. No files are needed to start from here.
  2. Solution Setup - Mesh to Results
    You can navigate to the Solution Setup section and work from setting up the simulation to visualizing the results. To begin here, download the SimLab database.
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
