Both single phase surface tension and adhesion modeling is based on the work of
        Akinci et al.
            Both models are capable of reproducing qualitatively realistic results, but are in
                principle unphysical and cannot be generalized for an arbitrary case/simulation.
                Because of this, trial-and-error tuning of the surface tension coefficient and the
                adhesion coefficient is necessary if realistic fluid behavior is to be achieved.
            Both adhesion and single phase surface tension models rely on a form inter-particle
                force, which binds the particles together. The way the force is modeled is through a
                specific kernel shape which mimics a potential energy well. In that sense, particles
                tend to keep a certain distance from each other and introduce elastic forcing if the
                particles get too close or too far from each other.
            The equation that dictates the adhesion force is given by:
(1)
                            F
                                a d
                                    n b r s
                                β
                                    m
                                    i
                                    W
                                        A k
                                    V
                                    i
                                        Δ
                                            x
                                                i j
                                            Δ
                                                x
                                                    i j
            While the single phase surface tension is defined by:
(2)
                            F
                                c o h
                                    n b r s
                                        2
                                            ρ
                                            0
                                            ρ
                                            i
                                            ρ
                                            j
                         γ
                            m
                            i
                            2
                            W
                                C o h
                                Δ
                                    x
                                        i j
                                    Δ
                                        x
                                            i j
            Where,
            Indicies
                                A
                                d
                      and
                                C
                                o
                                h
                      stand for adhesion and cohesion.
                                W
                      is the appropriate kernel used for each of the
                forces.
                                m
                      is the mass of the particle.
                                Δ
                                    x
                                        i
                                        j
                      is the distance between two interacting
                particles.
                                    ρ
                                    i
                      and
                                    ρ
                                    j
                      are instantaneous particle densities.
                                    ρ
                                    o
                      is the default density value of the particle
                phase.
                            β
                      is the adhesion coefficient.
                            γ
                      is the cohesion or surface tension coefficient.
            The
                            β
                      parameter is specified for each
WALL  or
MOVINGWALL  phase. That means that the
                level of adhesion can be different for every
WALL  or
MOVINGWALL  phase. The same applies to the
                            γ
                      value for the surface tension forces. The balance
                between surface tension and adhesion forces can replicate qualitatively the physical
                contact angles between the fluid and the solid elements. An example of balancing
                adhesion and surface tension forces is shown in
Figure 1 .
                Figure 1.  Single phase fluid droplet on a plate. Using different values of the adhesion and surface tension coefficient
                        produces effects of different contact angles.
            The adhesion model can be used in conjunction with the more physical multiphase
                surface tension model. In that situation, the surface tension forces are physical
                and only the adhesion model is left to be tuned, which can be a significantly easier
                exercise.
        Modeling Physical Behavior of Single Phase Surface Tension and Adhesion
            The nanoFluidX  team has performed a number of tests
                resulting in the development of consistent single phase surface tension and adhesion
                behavior. By consistency it is meant that if appropriate/desired behavior is found
                for a given resolution and a given surface tension or adhesion coefficient such
                behavior can be replicated for other resolutions by following the below
                methodology.
            The simulation data show that the variations of surface tension coefficient
                                σ
                                MathType@MTEF@5@5@+=
                                    feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
                                    hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
                                    4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb
                                    a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr
                                    0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape
                                    Gaeq4Wdmhaaa@37CC@
                      and adhesion coefficient
                                ϵ
                                    0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaamrr1ngBPrwtHr
                                    hAXaqeguuDJXwAKbstHrhAG8KBLbacfiaeaaaaaaaaa8qacqWF1pG8 aaa@4204@
                      due to particle spacing
                                    d
                                    x
                                    GaamizaiaadIhaaaa@37EF@
                      changes can be modeled as
                                    α
                                    d
                                        x
                                            β
                                    GaeqySdeMaamizaiaadIhapaWaaWbaaSqabeaapeGaeyOeI0IaeqOS
                                    digaaaaa@3C68@
                                α
                                    GaeqySdegaaa@37A8@
                      and
                                β
                                    GaeqOSdigaaa@37AA@
                      are case dependent and will take different values
                depending on the resolution and specific phenomena of the simulation. It is
                recommended to set
                                    β
                                    0.7
                                    GaeqOSdiMaeyypa0JaaGimaiaac6cacaaI3aGaaiiOaaaa@3C01@
                      and
                                    0.95
                                    GaaGimaiaac6cacaaI5aGaaGynaaaa@38F7@
                      for surface tension and adhesion, respectively.
            The procedure to obtain new
                                σ
                                    Gaeq4Wdmhaaa@37CC@
                      or when
                                    d
                                    x
                      changes is as follows:
                    Assume your current values are
                                            d
                                                x
                                                c
                                            GaamizaiaadIhapaWaaSbaaSqaa8qacaWGJbaapaqabaaaaa@3931@
                                                σ
                                                c
                                            Gaeq4Wdm3damaaBaaaleaapeGaam4yaaWdaeqaaaaa@390E@
                             , and
                                                ϵ
                                                c
                                            paWaaSbaaSqaa8qacaWGJbaapaqabaaaaa@4346@
                    You have a new
                                            d
                                                x
                                                n
                                            GaamizaiaadIhapaWaaSbaaSqaa8qacaWGUbaapaqabaaaaa@393C@
                              and want to find
                                                σ
                                                n
                                            Gaeq4Wdm3damaaBaaaleaapeGaamOBaaWdaeqaaaaa@3919@
                              and
                                                ϵ
                                                n
                                            paWaaSbaaSqaa8qacaWGUbaapaqabaaaaa@4351@
                    Set
                                            β
                                            0.7
                              for surface tension and use
                                            β
                                            0.95
                                            GaeqOSdiMaeyypa0JaaGimaiaac6cacaaI5aGaaGynaiaacckaaaa@3CC2@
                              for adhesion.
                    Use
                                            d
                                                x
                                                c
                              and
                                                σ
                                                c
                              or
                                                ϵ
                                                c
                              and solve for
                                        α
                                            GaeqySdegaaa@37A8@
                             .For example:
(3)
                                                α
                                                  σ
                                                  c
                                                  d
                                                  x
                                                  c
                                                  0.7
                                                GaeqySdeMaeyypa0ZaaSaaa8aabaWdbiabeo8aZ9aadaWgaaWcbaWd
                                                biaadogaa8aabeaaaOqaa8qacaWGKbGaamiEa8aadaqhaaWcbaWdbi
                                                aadogaa8aabaWdbiaaicdacaGGUaGaaG4naaaaaaaaaa@4162@
                             or
(4)
                                                α
                                                  ϵ
                                                  c
                                                  d
                                                  x
                                                  c
                                                  0.95
                                                GaeqySdeMaeyypa0ZaaSaaa8aabaWefv3ySLgznfgDOfdaryqr1ngB
                                                PrginfgDObYtUvgaiuGapeGae8x9di=damaaBaaaleaapeGaam4yaa
                                                WdaeqaaaGcbaWdbiaadsgacaWG4bWdamaaDaaaleaapeGaam4yaaWd
                                                aeaapeGaaGimaiaac6cacaaI5aGaaGynaaaaaaaaaa@4C5B@
                    Use the
                                        α
                                            GaeqySdegaaa@37A8@
                              computed above to find
                                                σ
                                                n
                              or
                                                ϵ
                                                n
                             .For example,
(5)
                                                  σ
                                                  n
                                                α
                                                d
                                                  x
                                                  n
                                                  0.7
                                                Gaeq4Wdm3damaaBaaaleaapeGaamOBaaWdaeqaaOWdbiabg2da9iab
                                                eg7aHjaadsgacaWG4bWdamaaDaaaleaapeGaamOBaaWdaeaapeGaaG
                                                imaiaac6cacaaI3aaaaaaa@4149@
                            or
(6)
                                                  ϵ
                                                  n
                                                α
                                                d
                                                  x
                                                  n
                                                  0.95
                                                paWaaSbaaSqaa8qacaWGUbaapaqabaGcpeGaeyypa0JaeqySdeMaam
                                                izaiaadIhapaWaa0baaSqaa8qacaWGUbaapaqaa8qacaaIWaGaaiOl
                                                aiaaiMdacaaI1aaaaaaa@4C42@
            These approximations are to save time when you want to change
                                    d
                                    x
                     . They are not perfect fits and some iteration maybe
                needed to find the adequate values.
