Workflow and Output
After ultraFluidX has been launched, it will read in the tessellated surface mesh, as well as the simulation parameters, and then start to generate the volume mesh based on the specified refinement zones.
When the volume mesh is ready and the surface mesh has been optimized according to the respective parameters, such as <triangle_splitting>, ultraFluidX will start the actual simulation on the GPUs and perform as many iterations on the coarsest refinement level as specified via <num_coarsest_iterations>. On higher refinement levels, the necessary number of sub-iterations will be performed according to the mesh size of the respective level.
Terminal Output
During the simulation, ultraFluidX will continuously write some output to the terminal, for example, the current coarsest iteration and the corresponding physical simulation time, the current drag, lift and side force coefficients, as well as the averaged computational performance and the presumable end of the simulation.
File Output
-o was omitted, see below) for the output of various result
                types: - uFX_coefficientsData
 - Folder including the instantaneous and averaged aerodynamic coefficients (uFX_coefficients_Inst.txt and uFX_coefficients_Avg.txt) and additional coefficient data per section or part, according to input in the <output> - <aero_coefficients> section.
 - uFX_fullData
 - Folder including the full output dataset according to the specifications
                            in the <output> - <general> section. This
                            folder contains all the output in EnSight Gold format.Note: ultraFluidX outputs the data in a distributed manner, per MPI rank. Additionally, a so-called “Server of Servers” file (uFX_output.sos) will be created that refers to the *.case files, per rank:uFX_output_#variable _RANK#rank_#timestep.data. Files that contain the actual result data, per variable, per rank, and per time step.
 - uFX_meshData
 - Folder with all mesh related output, including the mesh preview (if activated, see <meshing> - <general> - <mesh_preview>), the restart file (if activated, see <meshing> - <general> - <mesh_export>) and a list of void triangles that were removed from the specified tessellated surface mesh during meshing, if any.
 - uFX_surfaceData
 - Folder containing the surface data of the simulation results (output with respect to the respective parameter <output_frequency>), including the output of partial surface, if activated in the <output> - <partial_surface> section.
 - uFX_volumeData
 - Folder that contains the partial volume output, if specified in the <output> - <partial_volume> section.
