Batch Mode
Using HgTrans, you can convert all or a subset of data from a native file format to Altair Binary Format (ABF) via the batch mode process.
- PC
- \\Altair\hw\bin\win64
- Unix
- /altair/scripts/
Option/<Parameter> | Description |
-a | Translates all results to an ABF file without a configuration file. |
-c<config file> | The name of the configuration file(s).
-c<config file> and -c [space] <config file> are equal. |
-help or -h | Help. |
-o<output file> | The name of the ABF output file. |
<result file> | The name of the result file. |
-tho | Translates ODB results into an ABF file with only Time History Output -tho. |
-z [percent]<None|Standard|High> | Amount of lossless zlib compression. This does not effect load time in HyperGraph but does slow down the HgTrans translation. |
No options launch the HgTrans GUI.
