Bulk Data Entry OptiStruct calculates
        the ratio of
             and prints a WARNING if the frequency interval may not be
        fine enough for accurate Fatigue Damage calculation.
                            | Parameter | Values | Description |
                            | CHKM0 | <YES,
                                    NO> |
                                        YESOptiStruct calculates the
                                            ratio of
                                                . 1NO (Default)OptiStruct does not
                                            calculate the ratio of
                                                . 2
                                            Note: WARNING #4403 is not issued
                                                even if the frequency interval is not fine
                                                enough. Where,
                                                  0th moment (area under the PSD curve) is
                                                calculated using linear interpolation of stress
                                                PSD.
                                                  0th moment is calculated using
                                                logarithmic interpolation of stress PSD with the
                                                frequency interval of min (1Hz, minimum frequency
                                                interval of FRF analysis results). |
                - If
                        , a WARNING message is issued indicating that the
                    frequency interval does not seem fine enough for calculation of accurate
                    moments. This implies that the frequency interval may not be fine enough for
                    accurate Fatigue Damage calculation. A way to improve this is to increase number
                    of frequencies defined on the FREQi entries appropriately.
- If the frequency interval is fine enough, you can
                    expect
                         and
                         to be close to each other. If
                         is greater than or equal to 95% of
                        , the
                         value can become stable with regard to number of
                    frequencies. If the
                         value is stable, the subsequent Fatigue Damage
                    values are also stable.
