Open Files
Open a file.
- If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
 - Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
 - If the directory is not valid, the file dialog opens in the application start-in directory.
                Open a file one of the following ways:
- From the Home tools, Files tool group, click the Open Model tool.
Figure 1. - From the menu bar, select .
 - In the Open Model/Results Files dialog, browse for and select an *.hm model file and a respective result file (*.op2, *.h3d) to support the fatigue calculation.
 - Click Apply.
Click
 to pin a file
                    to the list.
