Undo-Redo
Undo and redo actions.
By default, the number of undo actions is set to 100 and the maximum undo memory (MB) is set to 2500. You can modify both of these settings by going to .
Undo/redo history may use a large amount of memory. By default, a threshold of 80% of the total memory limit will not be exceeded. Once the memory threshold is exceeded, all older actions will be automatically purged.
- Undo an action by clicking from the menu bar, or pressing Ctrl+Z.
 - Redo an action by clicking from the menu bar, or pressing Ctrl+Y.
