When defining a model, model resources identify additional files required for the
model to evaluate successfully, for example reference files called by script or linked
result files that were generated by other models.
Varnames can be referenced in the Solver Input
Arguments field, for example $file
, $filebase
, and so
on. The proper syntax is ${varname}
, for example
${m_1.file_2}
In the Define Models step, click Model Resources.
The Model Resources dialog opens.
- Optional:
Graphically view the model.
In the Model Resources dialog, click
Block View.
Click and drag items to rearrange the view of the model.
Use the options menu to determine which items display in the
window.
Select the model to which the resource will be assigned.
Click Add Resource and select the type of resource to
add.
In the Select dialog, navigate to your working directory
and open the file/folder/resource to reference.
Tip: To correct mistakes, right-click the resource file and select
Modify Resource from the context menu. The resource is maintained and the
operation is performed on a new file.
In the Operation column, select an option.
Click Close.
