Optimization Method Classification
Optimization methods can be categorized, with respect to their search technique, as iterative or exploratory. Iterative techniques can be either a local or global approximation.
Local Approximation Method (Gradient Based)
Local approximation methods are effective when the sensitivities (derivatives) of the system output responses with respect to input variables can be computed easily and inexpensively.
Local approximation methods require design sensitivity analysis (DSA) and are most suitable for linear static, dynamic and multi-body simulations.
Global Approximation Method (Response Surface Based)
Exploratory Methods
