Edit the Run Matrix
Edit the summary of run data stored in the run matrix by editing existing runs or adding new run data.
Edit Run Data
Manually edit existing run data in the Run Matrix.
Add Run Data
Manually enter new run data in the Run Matrix.
Import Run Data
Import run data into the run matrix from a plain text file, an approaches' evaluation data, or from a HyperStudy post processing file.
