A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration
point results or node-on-element results.
Allows translation of binary files across a platform. This function gives a list of arguments that allows you to tell
a program which machine wrote the binary file.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
HMRES_argumentcrossplatform()
Allows translation of binary files across a platform. This function gives a list of arguments that allows you to tell a program which machine wrote the binary file.
