A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
You can create external programs for processing plot data in the program using the C programming language. Altair IPC, or inter-process communication, allows you to exchange data between the Altair program and an external program.
There are five Altair IPC functions for exchanging data
Note: Only the Altair IPC functions are described in
this chapter. For more information on the C programming language, refer to
The C Programming Language by Brian W. Kernighan and Dennis M.
Ritchie.
