ardi.format
ardi.format.layout
Query layout information. This is valid only for report in Presentation format. Layout information originates from the Ms-office master document.
ardi.format.layout.exists
Queries whether or not a specific layout exists.
-name (mandatory)
Value: Name of the layout.
Returns
Boolean
ardi.format.layout.exists(name="One Table")
ardi.format.layout.getlist
Queries the list of available layouts.
Returns
The list of layout names.
ardi.format.layout.getmasterlayouts
Gets master slide layouts- only for Presentation.
None
Returns
The item ID's of master slide layouts.
ardi.format.layout.getslidelayouts
Gets list of slides from the imported presentation (only for Presentation).
None
Returns
The item ID's of slide layouts example.
