A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
Polyfit plus batch digital filter. batchpolyfit fits a polynomial to the data and subtracts that polynomial from the data, leaving only the residuals. It
batch filters the residuals, then adds the polynomial back in.
Returns the cumulative probability that a real-valued random variable x with a given continuous distribution will
be found to have a value less than or equal to x.
Creates a new x vector from the x vectors of multiple curves in the range between the maximum of all minima and the
minimum of all maxima. All curves must have an overlapping x range. The returned vector contains only the points of
the vector which has the most points in this range.
Magnitude of a Fast Fourier Transform (FFT) function. FFTMag performs a frequency analysis on a single curve's data
and produces an output that indicates the magnitude of the frequency content of the input file.
For a given set of x values, returns a vector of values that smoothly transitions from (or steps from) one level of
y value to another. This function can create a vector that has many steps and can use different forms of interpolating
step functions.
The OLC function is able to calculate both the Occupant Load Criteria (OLC) and OLC++. OLC++ combines OLC with the
time of maximum deformation (Tv=0) and the sliding mean integral over a window of 25 ms (SM25), as shown in the formulas
below.
Returns a vector or matrix of values based on the channel name (string), not on the index. Indices will only be used
for specifying the range of the returned vector.
The relative displacement (reldisp) math function allows you to transform vector results from time history or animation result files according to a
coordinate system defined by three nodes from the same result file.
Takes a vector and returns a vector containing the indices of the points from the input vector, which are non-duplicate
points (for successive points).
The rrs (Random Response Spectrum) is a standard mathematical function that is commonly used in random load analyses for
space systems. The rrs is defined as the rms response of a 1-DOF system as a function of its natural frequency for a given damping ratio.
Sliding mean integral filter. Smooths the curve by moving a sliding window over the curve and calculating the mean
value. This is done by calculating the area of the sliding window regardless of whether or not there are points at
the window boundary, and divides this area by the window size.
absarea
The total area between the curve and the independent axis regardless of sign.
abstorelative
Changes the reference to a file from absolute (root directory) to relative. The relative path will be the difference between path_1 and path_2.
batchpolyfit
Polyfit plus batch digital filter. batchpolyfit fits a polynomial to the data and subtracts that polynomial from the data, leaving only the residuals. It batch filters the residuals, then adds the polynomial back in.
bins
Creates bins for the probability density function, pdf.
cdf
Returns the cumulative probability that a real-valued random variable x with a given continuous distribution will be found to have a value less than or equal to x.
cellmax
Returns the maximum value of the referenced cells.
cellmean
Calculates the mean value of the referenced cells.
cellmin
Returns the minimum value of the referenced cells.
cellrange
Returns a vector of all referenced cell values of type scalar. This can be used to draw curves in HyperGraph based on cell values.
cellrms
Calculates the rms (the square root of the arithmetic mean of the squares) of the referenced cells.
cellrss
Calculates the rss (square root of the arithmetic sum of the squares) of the referenced cells.
cellsum
Calculates the sum of the referenced cells.
curveenv
Curve Envelope Templex function, which allows you to create a minimum and maximum envelope across given set of curves.
curvelabel
Returns the label of a curve being exported.
curvelength
Length of a segmented path along a curve.
curveproduct
Multiplies multiple curves which have overlapping x vectors.
curvesum
Adds multiple curves which have overlapping x vectors.
curvesync
Creates a new x vector from the x vectors of multiple curves in the range between the maximum of all minima and the minimum of all maxima. All curves must have an overlapping x range. The returned vector contains only the points of the vector which has the most points in this range.
curvex
Returns the X vector of a curve being exported or a curve in the current plot.
curvey
Returns the Y vector of a curve being exported or a curve in the current plot.
fcorr
Cross correlation function using Fast Fourier Transforms (FFT).
fftimag
Imaginary component of a Fast Fourier Transform (FFT) function.
fftmag
Magnitude of a Fast Fourier Transform (FFT) function. FFTMag performs a frequency analysis on a single curve's data and produces an output that indicates the magnitude of the frequency content of the input file.
fftphase
Phase angle of a Fast Fourier Transform (FFT) function.
fftreal
Real component of a Fast Fourier Transform (FFT) function.
mstep
For a given set of x values, returns a vector of values that smoothly transitions from (or steps from) one level of y value to another. This function can create a vector that has many steps and can use different forms of interpolating step functions.
nr
The Newton-Raphson method uses an iterative process to approach one root of a function.
nonlinfit
Returns a vector of fitted points according to the equation specified.
OLC
The OLC function is able to calculate both the Occupant Load Criteria (OLC) and OLC++. OLC++ combines OLC with the time of maximum deformation (Tv=0) and the sliding mean integral over a window of 25 ms (SM25), as shown in the formulas below.
polyval
Evaluates a given polynomial using specified coefficients and datapoints.
projectcurvetosurface
Projects a curve onto a surface or waterfall plot and returns the specified channel’s values of the projection in the specified direction.
read
Returns a vector from the specified data file.
readsim
Returns a vector or matrix of values based on the channel name (string), not on the index. Indices will only be used for specifying the range of the returned vector.
readsubcase
relativetoabs
Changes the reference to a file from relative to absolute.
reldisp
The relative displacement (reldisp) math function allows you to transform vector results from time history or animation result files according to a coordinate system defined by three nodes from the same result file.
remove_succ_dup_indx
Takes a vector and returns a vector containing the indices of the points from the input vector, which are non-duplicate points (for successive points).
rrs
The rrs (Random Response Spectrum) is a standard mathematical function that is commonly used in random load analyses for space systems. The rrs is defined as the rms response of a 1-DOF system as a function of its natural frequency for a given damping ratio.
smean (sliding mean integral)
Sliding mean integral filter. Smooths the curve by moving a sliding window over the curve and calculating the mean value. This is done by calculating the area of the sliding window regardless of whether or not there are points at the window boundary, and divides this area by the window size.
