The Design Circuit submenu contains the following macros:
 Opens the Feed System Wizard tab, which is a step-by-step procedure to create a generic or structure (gate, #n runners and sprue) feed system.  |
Create Lines |
CreateShortcut to the Lines panel.  |
EditShortcut to the Line Edit panel.  |
Line Mesh |
BeamShortcut to the Line Mesh panel.  |
Create/Edit Feed System |
Create Feed SystemOpens the Create Feed System dialog, where you can create property cards for a line mesh to create a new feed system.  |
Edit Solid DataOpens a selector for feed solids.  |
Edit Element DataOpens a selector for feed beam elements.  |
Create/Edit Cooling Circuit |
Create Circuit Opens the Create Cooling Circuits dialog, where you can create property cards for a line mesh to create a new cooling circuit.  |
Edit Property Card Opens a selector for property cards so you can edit the property card of an existing cooling circuit.  |
Edit Element Data Opens a selector for elements so you can edit the property card of the specified element.  |
<<< Back Opens the main Moldflow Utility menu.  |
MF-0020: Designing Feed Systems
