Manufacturing Solutions
File Types
File Types
File Types
HyperForm file types follow the standard naming convention: partname.suffix.  The suffix indicates the type of information contained in the file.  HyperForm recognizes the following file types:
.hf
HyperForm model file
.parm
HyperForm input deck
.out
Model and run information
.dat
Input data summary
.err
Error file
.res
Results files
_thk.nas
Nastran deck with stamped thickness distribution
_dyna.k
HyperForm output for DYNA analysis
opt.dat
Input deck for optimization runs
0000.rad
HyperForm output for RADIOSS analysis
0001.rad
.up
User process data file
Note: You must have write privileges in the working directory before modifying these files.
See Also:
User's Guide
