Manufacturing Solutions
Settings and Configuration Files
There are several files in the HyperForm installation that are used for storing settings related to the type of manufacturing simulation setup. These files are:
In the <install_directory>\hm\scripts\hyperform\automation directory:
File
process_defaults.dat
Contains default values for the velocities and binder force that appear under Setup in the Auto Process macro in addition to other process parameters.
settings.dat
Used to customize your setup while using the Multi-stage Manager and the Auto Process macros.
lsdyna.bat
Contains the location of the LS-DYNA solver executable.
In the <install_directory>\hm\scripts\hyperform\hydroform directory
CTRL-ALT-P
File
HydroformInitDefaults.dat
Contains the default recommended tool velocities and pressures used for hydroforming.
tubeBendingInitDefaults.dat
Contains default parameters related to the form tool location, rotational velocity, and rigid mass parameters recommended for tube bending.
