The Moldflow interface helps you prepare data for analysis in Moldflow and export it to native Moldflow formats. All steps, from data import to export, are available through the Utility menu, as shown in the image below.
Following the menu from top to bottom leads you through the design steps necessary to create data decks for export to Moldflow MPI. The Utility menu includes links to most common tools for creating models for Moldflow analysis; for more complex meshing, you may use additional panels and features. The process flow consists of the following major steps:
MF-0030: Setting Up a Basic Fusion Model
