The Surfaces group of the Utility menu enables you to perform geometry cleanup and extract midsurfaces.
• | The Cleanup button opens the Edge Edit subpanel, from which you can clean surfaces, trim surfaces, add or remove fixed points, etc. |
• | Use the Midsurface tool to extract a midsurface from a selected surface. |
