Calculate and plot responses specific to loadcases, including general loadcases, power train input, and road profile
input from an OptiStruct or Nastran Punch file.
Perform contribution analysis for the vehicle response between sensitivity and forces, with the respective files loaded
in the Loadcase Processing tab, the vehicle response calculated or loaded, and the loadcases selected in the Vehicle
Response tab, Powertrain input, or Road Profile input.
Perform a Partial sum response study by excluding the contributions from the selected contributors. The list of contributors
available depends on the diagnostics done before arriving at the Study tab.
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour
capabilities to isolate key contributing areas.
Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
The General Signal Processing utility processes the time domain pressure results from CFD simulations and visualizes
the results in both the time and frequency domain.
Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing
the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
Reads results from an OptiStruct optimization run and processes the results to review the overlay of the NVH responses, baseline versus optimized.
Compare changes in the design variable values, baseline versus optimized.
forces, with the respective files loaded in the Loadcase Processing tab, the vehicle
response calculated or loaded, and the loadcases selected in the Vehicle Response tab,
Order Contribution Tab
Overall response is plotted after you have selected the powertrain input loadcase in
the Vehicle Response tab with the corresponding sensitivity and forces result file
in the Loadcase Processing tab. The Order Contribution tab allows you to plot the
waterfall diagram and perform order cut analysis.
Order Cuts
After viewing the surface plot, use the Start, End, and Step fields to
specify the orders you want to see by cutting the surface plot.
Combine Order By - Choose between RSS and Arithmetic Sum to determine
how to combine the order curves to construct the overall response.
Display Options
The Display Options dialog allows you to customize the
overall response plot, including scale, weighting, and the
plot layout.
Load Response
Once your selections are complete, click Load Response to
create the orders and order sum response overlay plot.
Bar
Creates a bar plot of the response at a specific frequency
or RPM.
Enter a specific RPM in the Specific RPM field, or use the
slider bar to select an RPM value. When you use the slider
bar to select an RPM, a red line is displayed on the
response plot and is dragged simultaneously as you drag the
slider bar.
No. of highest order
After selecting the specific RPM, organize the
display by selecting the number of highest
orders.
Rank by
Define the method that is used to rank orders
with one of the following options:
Magnitude - Orders are ranked by the magnitude
of the order. Available for bar plot.
Display Options
The Display Options dialog allows you to further
customize the plot.
Display
Click Display to create and display the
plot.
2D Line
Creates a 2-D line plot of the response for a range of
frequency or RPM.
RPM range
Select the RPM range that the order curves
should be plotted within.
After defining the RPM range, organize the
display by selecting the number of highest orders.
Rank by
RSS Magnitude - Orders are ranked by the root
sum of squares of the magnitude of the order at
selected frequencies. Available for 2-D line and
3-D surface plots.
3D Surface
Creates a 3-D Surface plot of the response within an RPM range.
RPM range indicates the available range, based on your results
file.
Using the From and To fields, you can customize your own RPM range.
All other options are similar to those for the 2-D Line plot.
Load Path Contribution
After you have selected the powertrain inputs loadcase in the Vehicle Response tab,
with the corresponding sensitivity and forces results file in the Loadcase
Processing Tab, the Load Path Contribution tab allows you to perform contribution
analysis with respect to the sensitivity and forces for an RPM sub-case based on the
vehicle response.
Bar
Creates a bar plot of the response at a specific frequency.
Enter a specific frequency in the Specific Frequency field, or use the
slider bar to select a frequency value. When you use the slider bar to
select a frequency, a red line is displayed on the response plot and is
dragged simultaneously as you drag the slider bar.
Display Options
The Display Options dialog allows you to further customize
the plot.
Display
Click Display to create and display the plot.
2D Line
Creates a 2-D line plot of the response for a range of frequency.
Frequency range
Select the frequency range that the response curves should
be plotted within.
Wheel Contribution Tab
After you have selected the road profile inputs loadcase in the Vehicle Response tab
with the corresponding sensitivity and forces results file in the Sensitivity and
Forces Tab, the Wheel Contribution sub-tab allows you to perform a contribution
analysis with respect to the wheel contribution and sensitivity for a vehicle
response, corresponding to the random loads subcase.
Bar
Display Options
the plot.
Display
the plot.
2D Line
Frequency range
be plotted within.
