Constant Damping Block
Constant Damping blocks store the damping coefficient for a given direction.
Parameter | Type | Dimension FX, FY, FZ | Dimension TX, TY, TZ |
C | real | [F][L-1] | [F][L][A-1] |
[CONSTANT_DAMPING_FX]
block. The form of the block
is:[CONSTANT_DAMPING_FX]
C = 600.0
The dimension for the damping coefficient for translational directions is [F][T][L-1] and for rotational directions [F][T][L]. When read from the property file, the damping coefficient is converted from the units defined in the property file to the solver model units.
