Run MIT From HyperGraph
To run the MIT from HyperGraph for the first time, follow steps 1-2. After the initial setup, you can run the MIT from the HyperGraph toolbar as you see in Step 3.
Quick introduction to Altair HyperWorks products.
Discover the functionality of Altair HyperWorks products with interactive tutorials.
Administrative tools to customize your Altair HyperWorks installation.
The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted Altair Units.
Altair Compute Console (ACC) is a utility that allows you to start different Altair HyperWorks Solvers.
Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2018 (or earlier) to Abaqus 2023.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Cleanup Utility is a script for Windows that removes any custom settings that you may have due to the Altair applications installed.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
This section explains how to start the MIT interactively and in batch mode.
This section explains how to use the features in HWTK GUI Toolkit.
The Altair Bushing Model is a library of sophisticated, frequency- and amplitude-dependent bushing models that you can use for accurate vehicle dynamics, durability and NVH simulations. The Altair Bushing Model supports both rubber bushings and hydromounts.
This section provides information about using the Altair Bushing Model, also known as AutoBushFD, with MotionView. The Altair Bushing Model is a sophisticated model that you can use to simulate the behavior of bushings in vehicle dynamics, durability and NVH simulations.
This section provides information about using the Altair Bushing Model, also known as AutoBushFD, with MotionSolve.
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
The H3D Validation Tools available are H3D Info and H3D Validate.
Use the Altair HyperWorks Products Uninstaller to remove all files from the installation directory.
ON THIS PAGE
ON THIS PAGE
