Response Module#
DeviationSquared
Computes the difference between a function's current value and a desired value.
GenericResponse
Creates a generic response.
MaxVal
Computes the approximate maximum value of a MotionSolve expression or a user subroutine during the simulation.
MinVal
Computes the approximate minimum value of a MotionSolve expression or a user subroutine during the simulation.
RMS2
Computes the root-mean-square area difference between a measured signal and a target curve.
ResponseExpression
Computes the value of an arbitrary function that is composed of design variables and other responses.
SignalDistance
Computes the distance between two signals by dynamic time warping.
Slope2
Computes the slope of a curve at a particular point of interest t.
Slope2Deviation
Computes the square of the deviation of the slope of a curve at a certain point in time from a target value.
ValueAtG
Computes the value of a signal, f when a second signal G achieves a certain value C.
ValueAtTime
Computes the value of a signal at a certain time T.
