This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
Geometric Properties ElementPBEAM9 lets you specify the geometric properties for an associated beam element of an arbitrary cross-section using
a polynomial expression
PABUSH Geometric Properties ElementPABUSH lets you specify the bushing properties for an associated bushing element.
PBEAM9 Geometric Properties ElementPBEAM9 lets you specify the geometric properties for an associated beam element of an arbitrary cross-section using a polynomial expression
PBEAMA Geometric Properties ElementPBEAMA lets you specify the geometric properties for an associated beam element of an arbitrary cross-section
PBEAMC Geometric Properties ElementPBEAMC lets you specify the geometric properties for an associated beam element of a circular cross section
PBEAML Geometric Properties ElementPBEAML lets you specify the geometric properties for an associated beam element of a specific cross section type.
PCABLE Geometric Properties ElementPCABLE lets you specify the geometric properties for an associated cable element.
PLINE Geometric Properties ElementPLINE lets you specify the properties for an associated line spring element
