OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
This tutorial demonstrates how to perform direct transient dynamic analysis using OptiStruct using an existing finite element model of a wing structure. HyperView is used to post-process the deformation characteristics of the Wing Structure under the transient dynamic loads.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
OS-HM-T: 2000 Direct Transient Analysis of Airframe Model
